1992 Toyota Celica Flip-Up Light Stuck
1992 TOYOTA
ODERUS
The right flip-up light on my toyota is stuck down. Where exactly is the motor so I can manually crank it up? And once it is up, is it okay to leave it up or does it need to be down to avoid any extra problems?
May 2, 2006 at 2:04 AM
LOSONE
  • 1,616 POSTS
The motor is directly behind the headlight assembly. It won't hurt to leave it up, just look a little wierd with one up and one down.
May 2, 2006 at 2:10 AM
ODERUS
Thank you very much for the info. I appreciate your swift reply.
May 2, 2006 at 2:20 AM
Suggested Repair
The flip-up headlight motor is directly behind the headlight assembly and can be manually cranked from there. Leaving the light up will not cause extra problems, though one light up and one down will look uneven.
Conversation Summary
The owner of a 1992 Toyota Celica asked where the right flip-up headlight motor is so it can be cranked up manually, and whether leaving it up causes problems. The expert said the motor is directly behind the headlight assembly and that leaving the light raised is fine, though it looks odd with one up and one down.
