1995 Toyota Celica RPM Ticking Noise
MACD41144
I have a 95 Celica LE with about 199,000+ miles. I'm the second owner. The first owner, my aunt, got the oil changed every 3,000. I have kept up with that routine. All major repairs have been done at the dealership where it was bought new. It runs great except it started making an odd noise. It's a metallic fluttering/ticking which only happens once I get to about 3100 rpms, and stops around 4100 rpms. The idle is occasionally rough, but if I tap the gas, that goes away. Otherwise the car is in great condition. I don't believe I have lost any power to the car. Does anyone know what might be the problem at 3100 rpms?
May 18, 2007 at 12:42 PM
  • 75,988 POSTS
[quote:fc41e2e378="macd41144"]I have a 95 Celica LE with about 199,000+ miles. I'm the second owner. The first owner, my aunt, got the oil changed every 3,000. I have kept up with that routine. All major repairs have been done at the dealership where it was bought new. It runs great except it started making an odd noise. It's a metallic fluttering/ticking which only happens once I get to about 3100 rpms, and stops around 4100 rpms. The idle is occasionally rough, but if I tap the gas, that goes away. Otherwise the car is in great condition. I don't believe I have lost any power to the car. Does anyone know what might be the problem at 3100 rpms?[/quote:fc41e2e378]
Could be the timing belt or the adjusting discs between the cam follower and lifters/or liters itself.
Could also be the exhaust heat shield.
May 18, 2007 at 7:33 PM
Suggested Repair
Inspect the timing belt, the adjusting discs between the cam followers and lifters, and the lifters themselves. Also check the exhaust heat shield for a metallic flutter or tick between about 3100 and 4100 rpm.
Conversation Summary
The owner of a high-mileage 1995 Toyota Celica LE reports a metallic fluttering or ticking noise only between about 3100 and 4100 rpm, plus an occasional rough idle that clears after tapping the throttle. Power otherwise seems normal and maintenance has been regular. The expert suggests the timing belt, cam-follower adjusting discs or lifters, or the exhaust heat shield as possible causes.
