1987 Toyota Celica PCV and Fuel Filter
TURBO101
  • 8 POSTS
I have a 1987 Toyota Celica St,2.0 4-cylinder FE Engine..EFI
My problem is that i cannot pin point the fuel filter and the pcv valve?
Any suggestions??
May 9, 2007 at 3:41 PM
  • 75,988 POSTS
[quote:7af6cd9712="Turbo101"]I have a 1987 Toyota Celica St,2.0 4-cylinder FE Engine..EFI
Any suggestions??[/quote:7af6cd9712]
Sir
What do you mean-where is it or how you troubleshoot it.
Carb or EFI 20R engine.
May 9, 2007 at 5:49 PM
TURBO101
  • 8 POSTS
where is it located
May 10, 2007 at 10:55 AM
  • 75,988 POSTS
[quote:8f2e765a04="Turbo101"]where is it located[/quote:8f2e765a04]
The PCV valve is right on top of the valve cover the big hose toward the front.
Fuel Filter if its a carb its near the gas tank, EFI its under the intake manifold.
HTH Good Luck
May 10, 2007 at 11:08 AM
Suggested Repair
Locate the PCV valve on top of the valve cover, where the large hose runs toward the front. On this EFI engine, look for the fuel filter under the intake manifold.
Conversation Summary
The owner of a 1987 Toyota Celica ST with a 2.0L EFI engine could not locate the PCV valve or fuel filter. The expert said the PCV valve is on top of the valve cover at the large hose toward the front, and that an EFI fuel filter is under the intake manifold.
