1983 Toyota Celica No Fuel to Injectors
TRALSTON1232
I have a 1983 Celica GT 22RE manual that is having fuel flow problems. When the problem occurred the car was running fine, in a heavy rain, then started balking and quit, and then wouldn't restart. After a delay of a day, it would start on the cold start injector for a second, then quit.
The fuel pump works when I short the fuel pump service test connector. I'm getting fuel pressure within spec from the fuel line.
Local mechanic ran a hour worth of diagnostics and said it was either the distributor or the fuel shutoff. I can't find any evidence of a fuel shutoff solenoid or similar valve. I've replaced the distributor with a working distributor. Still no gas getting to the injectors.
Any thoughts or help greatly appreciated.
Apr 7, 2007 at 6:05 AM
  • 75,988 POSTS
[quote:58eb322f53="tralston1232"]I have a 1983 Celica GT 22RE manual that is having fuel flow problems. When the problem occurred the car was running fine, in a heavy rain, then started balking and quit, and then wouldn't restart. After a delay of a day, it would start on the cold start injector for a second, then quit.
Any thoughts or help greatly appreciated.[/quote:58eb322f53]
If the computer don't see a signal the Ne and G it will not energize the injectors.also better check the EFI resistor it has to go thru there to power the injectors then the computer grounds it to complete the circuit.
Apr 7, 2007 at 10:16 AM
Suggested Repair
Verify that the ECU receives Ne and G signals, because missing signals prevent the injectors from being energized. Also test the EFI resistor that supplies power to the injectors before the computer grounds the circuit.
Conversation Summary
The owner of a 1983 Toyota Celica GT 22RE says the engine quit in heavy rain and will not stay running. Fuel pump operation and fuel pressure are within spec, and replacing the distributor did not restore fuel to the injectors. The expert says the computer will not energize the injectors without Ne and G signals and recommends checking the EFI resistor in the injector power circuit.
