1985 Toyota Celica Caution Lights Out
LOCBOY
i hardwired a kenwood cd player inside my car and my caution lights won't come on.that's when i noticed the problem.My head and signal lights come on but not the caution lights. Are they not coming on because i may have used or cut a wire or what? And my friend has the same problem with his 1987 pickup but his signal or caution lights won't come on just his headlights. can somebody help
Dec 11, 2006 at 1:44 PM
  • 75,988 POSTS
Take it back out and make sure all the wires that you cut goes back to the same wire do a good splice. see what happen to the caution lite.
I will give you the existing wire color code so that you can hook it up properly and the kenwood color code wire. Its your shot.
Dec 11, 2006 at 3:58 PM
LOCBOY
ok wat about my friend do the same solution for him
Dec 12, 2006 at 3:49 AM
  • 75,988 POSTS
Do yours first and see what happens. Make sure you insulate and tug the wires properly to prevent chafing and short to ground.
Dec 12, 2006 at 5:50 AM
Suggested Repair
Remove the stereo wiring and match every cut wire back to its original circuit with a solid splice. Insulate and secure the joints so they cannot chafe or short to ground, then recheck the caution lights. Repair the Celica first before trying the same approach on the pickup.
Conversation Summary
The owner of a 1985 Toyota Celica hardwired a Kenwood CD player and then found the caution lights would not come on, although the headlights and turn signals still worked. A friend with a 1987 pickup has a similar lighting problem. The expert advised restoring each cut wire to its original circuit with a proper splice, insulating and securing the connections to prevent chafing or a short to ground, and fixing the Celica first.
