1993 Toyota Celica Fuel Cap Hiss
THE_HYDROXIDE_CHILD
  • 82 POSTS
I Have a 1993 Celica 2.2L everytime i get gas and i take the cap out it hisses for like 3 seconds.... now i was let to believe this is a bad cap cuz its not venting right and the tank is sucking itself so tight when i open it its rushing air into it.... if this is true will my gas tank implode??? or is it pressure rushing out???..... or should i buy a new gas cap....???
Apr 16, 2007 at 7:21 AM
  • 75,988 POSTS
[quote:5f35b2ff41="the_hydroxide_child"]I Have a 1993 Celica 2.2L everytime i get gas and i take the cap out it hisses for like 3 seconds.... now i was let to believe this is a bad cap cuz its not venting right and the tank is sucking itself so tight when i open it its rushing air into it.... if this is true will my gas tank implode??? or is it pressure rushing out???..... or should i buy a new gas cap....???[/quote:5f35b2ff41]
No its not gonna explode-it will collaspe
Sounds like a purging problem check out the Evap system also consider the cap.
Apr 16, 2007 at 8:56 AM
THE_HYDROXIDE_CHILD
  • 82 POSTS
well ty :p.... and i did say implode not explode lol but its ok..... ty for responding tho..... greatly appreciated.... and by evap system u mean charcoal canister right???
Apr 16, 2007 at 7:15 PM
  • 75,988 POSTS
[quote:165805f349="the_hydroxide_child"]well ty :p.... and i did say implode not explode lol but its ok..... ty for responding tho..... greatly appreciated.... and by evap system u mean charcoal canister right???[/quote:165805f349]
Check the purging solenoid and C/C
Keep fixing it- till it breaks
Apr 16, 2007 at 8:14 PM
Suggested Repair
Check the EVAP purge solenoid and charcoal canister for a purging problem, and also inspect or replace the gas cap if it is not venting correctly.
Conversation Summary
The owner of a 1993 Toyota Celica 2.2L hears a several-second hiss when removing the fuel cap after filling up and worries the tank is under vacuum and could collapse, or that pressure is escaping. The expert says the tank will not explode but can collapse, and attributes the symptom to an EVAP purging problem. The expert recommends checking the purge solenoid and charcoal canister and also considering the gas cap.
