brake light
TOYOTA CELICA
LABORMATES
I have a 92 toyota celica st the problem is that when i hit the brakes the passager side light for the brake goes completely out and when i let off the brake its fine. the driver side brightens up and dims like it should whats the problem. thank you
Feb 7, 2007 at 8:07 AM
[quote:9c0ea3253a="labormates"]I have a 92 toyota celica st the problem is that when i hit the brakes the passager side light for the brake goes completely out and when i let off the brake its fine. the driver side brightens up and dims like it should whats the problem. thank you[/quote:9c0ea3253a]
Check the bulb socket for corrosion
Feb 7, 2007 at 10:32 AM
LABORMATES
[quote:26988e1adb="rasmataz"][quote:26988e1adb="labormates"]I have a 92 toyota celica st the problem is that when i hit the brakes the passager side light for the brake goes completely out and when i let off the brake its fine. the driver side brightens up and dims like it should whats the problem. thank you[/quote:26988e1adb]
Check the bulb socket for corrosion[/quote:26988e1adb] thanks i'll try it and see if it works
Feb 7, 2007 at 12:49 PM
