2003 Toyota Celica Headlight change...
2003 TOYOTA CELICA
NATHANEVISON
Electrical problem
2003 Toyota Celica Wheel Drive Type unknown Automatic 75000 miles
It's a pathetic question, but I need some help trying to change my fiancee's headlight. The headlight that is needing replacement is on the driver-side of the car. Not really sure the proper procedure?? Thanks for your help!
Jan 2, 2008 at 10:41 PM
FISHERMAN
  • CAR REPAIR CONTRIBUTOR
  • 937 POSTS
[quote:fd0661a14b="nathanevison"]Electrical problem
It's a pathetic question, but I need some help trying to change my fiancee's headlight. The headlight that is needing replacement is on the driver-side of the car. Not really sure the proper procedure?? Thanks for your help![/quote:fd0661a14b]
Hello !!
well most of the Halogen light bulbs of the headlights are "turn-lock" and have a "o"ring to seal them..
Try to turn the back connector on the back of the headlight (a quarter of a turn) and pull it gently (be sure no to touch the new halogen light bulb with your fingers because it can get contaminated and burn faster)
Good Luck!
Jan 2, 2008 at 10:55 PM
