1990 Toyota Celica Dash Lights Flicker
TEMMUCHIN
I'm having a problem with my dash lights. They turn off everytime I hit a bump and turn on again next time I hit a bump. Sometime they don't turn on at all unless I tap tap the dimmer for a minute or two. It's probab;y a loose wire, but I don't have the slightest idea where to start looking. I would appreciate any advice. I'm trying to learn but I don't know much about cars so please keep it as simple as possible. Thanks for your time.
Jun 6, 2006 at 4:33 AM
LOSONE
  • 1,616 POSTS
Dash lights are controlled by the lightswitch via the light dimmer control. It is hard to say which one is causing the problem. Even the best of mechanics have to hunt for this one. It probably is a loose connection on the back of your instrument cluster unless you have installed an aftermarket radio, then it may narrow the problem. Good luck
Jun 6, 2006 at 5:56 AM
Suggested Repair
Check the light switch and dimmer control, and inspect for a loose connection on the back of the instrument cluster. If an aftermarket radio was installed, also check the related wiring.
Conversation Summary
The owner of a 1990 Toyota Celica reports dash lights that go out over bumps and come back after another bump, sometimes only turning on after tapping the dimmer. The expert says the lights are controlled by the light switch through the dimmer, so either could be at fault, and a loose connection behind the instrument cluster is likely unless an aftermarket radio was installed.
