1993 Toyota Celica Lights Dim and Flicker
KGOPEL
  • 13 POSTS
I recently replaced the headlight assemblies for this car after an accident. I spliced the wires. This was fine for over a year and half, now whenever I press the brake pedal, the dash lights, headlights, etc. dim almost completely out and come back on. Also noticed a flickering of the dash and headlights while driving. Is there a loose connection or something else like a headlight switch (NOT EVEN SURE IF THIS HAS A HEADLIGHT SWITCH) Any info would help. Thanks
Mar 12, 2006 at 2:20 AM
  • 75,988 POSTS
Flickering can be cause by the IVR
Headlite relay going bunkers
Combination switch defective
Loose connection
An overload exist
Try doing a battery drain test anything over 0.30ma is no good start tracking for a short
Mar 17, 2006 at 7:28 PM
Suggested Repair
Check the instrument voltage regulator, headlight relay, combination switch, and wiring for a loose connection or overload. Perform a battery drain test; draw above 0.30 mA is excessive and should be traced for a short.
Conversation Summary
The owner of a 1993 Toyota Celica GT with 150,000 miles says the dash lights and headlights dim nearly out when the brake pedal is pressed, then come back, and also flicker while driving. Headlight assemblies were replaced and the wires spliced after an accident, and the car ran fine for more than a year. The expert lists a faulty instrument voltage regulator, failing headlight relay, defective combination switch, loose connection, or overload as possible causes, and recommends a battery drain test with anything over 0.30 mA treated as excessive and traced for a short.
