1991 Toyota Celica
LILBROVO
  • 1991 TOYOTA CELICA
  • 4 CYL
  • FWD
  • MANUAL
  • 153,000 MILES
I have a 1991 toyota celica gt, has about 153,000 miles on it. I just replaced the oil pump, water pump, timing belt, and ignition wires. After test driving it, a scraping, clicking noise popped up, kind of like a struggling noise. This happenes in 1st gear when accelerating, and then in 2nd, 3rd, 4th and 5th gears only when accelerating at higher rpms ( around 2500-3000 rpm). It happened before the tune up, but only once in a while in 1st gear. The parts store said to change the gear oil, but I did that already, and still no change. I checked every where, body/engine, but still couldnt find where the noise was coming from. Its my first car and im still in school, I could really use some help. Thanks.
Sunday, June 13th, 2010 AT 11:57 PM
  • 31,937 POSTS
Hi there, listen carfully to the noise, is it engine speed or 1/2 engine speed? What do you think.
Mark (mhpautos)
Monday, June 14th, 2010 AT 4:26 AM
LILBROVO
What do you mean? Do you mean is it losing power?
Tuesday, June 15th, 2010 AT 12:38 AM
  • 31,937 POSTS
No, the noise, dose it sound constant with engine speed or do you think that it is less then engine speed,
mark
Tuesday, June 15th, 2010 AT 12:53 AM
LILBROVO
Oh, ok. Well the noise is constant with the engine speed. It runs good except for the noise that is noticeably louder than before the tune up, and it only happens when I accelerate, not decelerating or at idle. What do you think it is?
Tuesday, June 15th, 2010 AT 2:21 AM
  • 31,937 POSTS
Find out if the tensioner bearing was replaced, check that it is not a noisy alternator or the plastic timing cover touching the harmonic balancer or the timing belt and making a noise.
Mark (mhpautos)
Tuesday, June 15th, 2010 AT 5:24 AM
