1993 Toyota Celica Water pump leaking and I think I need a
1993 TOYOTA CELICA
168,000 MILES • 4 CYL • FWD • MANUAL
LADYVENUS1962
Where is my starter located in my 1993 Toyota Celica? And it leaks water I think from a seal on the water pump. Can I fix that myself?
Jul 15, 2008 at 2:16 PM
  • 31,937 POSTS
Hi there,
The starter is mounted on the engine where the gearbox bolts up, The water pump will require the timing belt to be removed so if you feel that this is beyond your capabilities, get your mechanic to do this job.
Mark (mhpautos)
Jul 15, 2008 at 2:33 PM
