Unsolvable Camry Engine Problem
BOROC7
Nobody can seem to understand what's wrong with my car. I have a Toyota Camry 1992 V6 XLE. When I drive it for longer periods of time (30+min), and then I get into a traffic situation or when I am going slow and am in first gear, I can hear a kind of whining fan noise coming from my engine that corresponds to how much accelerator I give it. When that starts to happen, my thermometer starts to go crazy and jump around, but it never overheats too much--yet. Sometimes it even drops a bit. Mostly, it bounces. Once I get to 2nd or 3rd gear and have some speed, the needle returns to normal and the sound stops. Then after that drive, when I leave the car and then come back to start it, the idle will drop immediately after it starts and stall, repeatedly. The only way I can drive it is if I give it a lot of gas and quickly start driving. This doesn't happen every time, usually on long drives. Any thoughts on this?
Jan 30, 2007 at 6:06 AM
LOSONE
  • 1,616 POSTS
There is a recall on that V-6 engine. They came with bad head gaskets and it will create odd symptoms like yours. Check out the VO-6 free Toyota recall.
Good luck losone
Feb 5, 2007 at 4:55 AM
LOSTINMARS
  • 222 POSTS
toyota didn't recall this engine, they recalled the v6 engine in some of the pickups due to head gasket leaks.
you're car should have a hydraulic fan that operates off the p/s system. i'd start by check that out first.
Feb 6, 2007 at 1:22 PM
