Car won't start, intermittent
OPTIONS18
  • TOYOTA CAMRY
1995 toyota camry, 185000 miles, just recently my car won't start. Then all of the sudden it will start. The dome light, radio, dash lights are working but nothing. It doesn't even make a sound. I have replaced the battery and cables and it continues to do it. Does anyone have any ideas before I pull my hair out? Thanks
Saturday, May 26th, 2007 AT 1:07 PM
Check the starting system-Battery/Connections, Ignition switch, NSS, starter relay and starter
Saturday, May 26th, 2007 AT 7:31 PM
USER823
  • 6 POSTS
If you are certain the battery is good and the connections are okay, check if there is a fuse in your vehicle for the ignition. My car has a fuse on the interior fuse panel labeled as 'ignition' that, if removed, will cause the car to totally fail to turn.
Tuesday, May 29th, 2007 AT 1:03 PM
