1996 Toyota Camry Key Won't Turn
JAYROO
I have a 1996 Toyota Camry that my fiance gave me three months ago. Recently I have been trying to start it and put the key in and it wont turn at all. The wheel turned but no matter what the key will not turn. The battery works and theres gas in it, but the key wont turn. I dont know it if this is a problem with the ignition or the key. What might be some problems with it?
Mar 5, 2007 at 12:09 PM
  • 75,988 POSTS
Have the shift interlock system check-its not a DIY
Mar 5, 2007 at 6:24 PM
JOEMECHANIC
  • 28 POSTS
Yes,also often on these toyotas the shift linkage comes out of adjustment after much use,and the selector lever will be out of sync with the rest of the interlock system,a simple adjustment,but requires a basic knowledge of this system,try jiggling the shift lever while turning the key,and pressing the brake,this sometimes works
Mar 12, 2007 at 10:38 AM
Suggested Repair
Have the shift interlock system and shift linkage checked and adjusted by someone familiar with the system. Try jiggling the shift lever while turning the key and pressing the brake, which sometimes frees the key.
Conversation Summary
The owner of a 1996 Toyota Camry says the key will not turn in the ignition even though the steering wheel moves, the battery works, and there is fuel. Experts point to the shift interlock and a shift linkage that may be out of adjustment, and suggest jiggling the shifter while turning the key and pressing the brake. They note the adjustment is not a DIY job.
