Toyota Camry engine leak
PEJEDRA
  • TOYOTA CAMRY
I have a 1996 toyota camry, 4 cylinder with 87,000 miles. There seems to be a oil leak and it is burning off the exhaust and causing the car to smoke. When I check the oil level, it doesn't go down any from the leak. My mechanic even put a dye in the oil to try to find where the oil is coming from, but still cant find it. The car runs great otherwise, but we are puzzled as to where the leak may be. Does anyone has any suggestions?
Friday, August 24th, 2007 AT 11:23 AM
SERVICE WRITER
  • 9,123 POSTS
He needs to run it until the smoke is there and up on the lift to get to the source.
Friday, August 24th, 2007 AT 11:36 AM
SAA7C4
Did you find soulution for your car becuase my car has similar prob to yours and until now I did not get soultion.
Friday, August 31st, 2007 AT 6:43 PM
