1996 Toyota Camry Oil Leak
RICHARDWOOD
Hello, I have a 2.2L 1996 Camry LE, 225,000 miles. I have an oil leak that I have traced to be coming from possibly behind the timing chain. There appears to be a channel for oil or something to flow down from behind the timing chain down toward the oil pan. At first I thought the problem was the oil pan, until I changed the gasket and still had a leak. That's when I tracked it to behind the timing cover. What would be going out to cause the leak? I would appreciate any help. Thanks
Nov 18, 2007 at 2:05 PM
  • 75,988 POSTS
Could be the camshaft oil seal or the front seal
Nov 18, 2007 at 10:29 PM
Suggested Repair
Inspect the camshaft oil seal and the front crankshaft seal behind the timing cover, since the leak continued after the oil pan gasket was replaced.
Conversation Summary
The owner of a 1996 Toyota Camry LE 2.2L with 225,000 miles has an oil leak that continued after replacing the oil pan gasket. They traced oil flowing from behind the timing cover toward the oil pan. The expert suggested the camshaft oil seal or the front seal as possible sources.
