I recently bought this car (Dec06) and then I noticed an oil leaking problem which I got it fixed but still was minor oil leakiing. That time, mechanic told me that your transmission fluid needs to be changed and after some time, I got changed all oils from expresslube but didn't cange transmission fluid. Then again oil started leaking after changing and I showed to the expresslube again, they said oil was overflowing, thats why it was leaking.
Then after one wek, I got changed transmission fluid also but from different mechanic. After changing all oils, I noticed that oil started laking badly, it was all over where I parked the car.
Please give me suggestion what should I do now and what basically is the problem as I know little about transmissions.
Thanks
SPONSORED LINKS
Tuesday, May 22nd, 2007 AT 1:15 PM
