Much Thanks, Ray
1988 Toyota Camry Distributor Oil Leak Fix
There is an O-ring that seals the distributor to the head. You remove the distributor, replace the O-ring and reinstall the distributor.
Jul 5, 2007 at 11:43 PM
[quote:9a63bf2674="mmprince3000"]There is an O-ring that seals the distributor to the head. You remove the distributor, replace the O-ring and reinstall the distributor.[/quote:9a63bf2674]
I'm aware of the O ring, but if I don't get to it right away, will I muck up the inner workings of the distributor?
Ray
Ray
Jul 6, 2007 at 12:44 PM
you will not damage the distributor, but you could damage the engine if you do not keep it full on oil. Also it is not completely safe since the oil could leak and with the exaust it could catch fire. Not a for sure thing, but I have seen it happen. It is one of those things that it could be fine forever (as long as you keep it full of oil), or it could be hazardous. I would personally get it fixed as soon as I could.
Jul 6, 2007 at 12:51 PM
Suggested Repair
Replace the O-ring that seals the distributor to the cylinder head by removing and reinstalling the distributor. Keep the engine oil full and repair the leak soon because low oil can damage the engine and oil near the exhaust could pose a fire risk.
Conversation Summary
The owner of a 1988 Toyota Camry reports a slight oil leak at the distributor and asks whether it can wait because they can no longer do the work. An expert says an O-ring seals the distributor to the head and should be replaced by removing and reinstalling the distributor. A follow-up reply says delay will not damage the distributor itself, but the oil level must be kept full to protect the engine, and leaking oil near the exhaust could catch fire, so the leak should be fixed soon.
