Starting problem
SLEMASTER01
  • TOYOTA CAMRY
1990 Toyota Camry V6 141,000 miles standard 5 speed. The problem I am having is that when I shut off my car it will not start back up. Battery is good alternator is new. Replaced alterator last week. Had it tested and it was bad. The battery is charging when car is running at about 14V. So there is no problem with the charging system. After the car sits all night or after about 2 hours it will start but when I shut the car off after running it will not start back up immediatly. It seems after the car cools off it will start.
Sunday, November 18th, 2007 AT 2:15 PM
Check the fuel pressure and comeback with the readings. Before we head on over to the ignition system
Sunday, November 18th, 2007 AT 4:45 PM
