2000 Toyota Camry Radio Loses Presets
PIPIN
After overnight parking, when I start my 2000 Camry (100,000) miles and turn on the radio, all previous programed stations are lost. What could be the problem?
Feb 27, 2006 at 2:54 AM
FISHERMAN
  • 937 POSTS
its that an Original radio?
Feb 27, 2006 at 5:59 AM
PIPIN
yes it is.
Feb 27, 2006 at 6:25 AM
FISHERMAN
  • 937 POSTS
there is a "hot wire" 12 vdc (+) that provide a constant voltage to the radio, the way it "keep" the memory...
and should be "fused" if possible check the back of your radio for loose connector and all of the fuses...
i dont know what else could be the problem..
Feb 27, 2006 at 7:27 AM
PIPIN
Thank you, I'll check that out.
Feb 27, 2006 at 7:33 AM
Suggested Repair
Check the constant 12-volt memory power wire to the original radio, its fuse, and the rear radio connector for a loose connection.
Conversation Summary
A 2000 Toyota Camry with about 100,000 miles loses all radio presets after sitting overnight. The owner confirmed the radio is original. The expert explained that a fused constant 12-volt hot wire maintains the radio memory and advised checking the fuses and the connector at the back of the radio. The owner planned to check those items.
