Pls Suggest - Engine Problem!
MIHIRDESHPANDE
  • TOYOTA CAMRY
I have a Toyota Camry 1998 with 127000 Miles on it. It has a 2.2 Liter 4 Cylinder Engine. Yesterday, while driving back from my work, the engine suddenly shut off and the oil cluster light started blinking. I noticed that the engine oil started leaking and also the engine was too hot( as was shown in the cluster display). Later I realised that it was the coolant that was leaking and the whole coolant drained out. When I added water inside the radiator, it all drained out near the passenger tire. Pls, Tell me, what could be the problem with the car?
Sunday, October 14th, 2007 AT 5:14 PM
BUZZSAW
  • 1,198 POSTS
May be a water pump, the t-belt cover needs to come off, then you can see more, if coolant got on the belt replace it also
Sunday, October 14th, 2007 AT 10:55 PM
