1992 Toyota Camry Rear Door Handle
LATASHAP
how to replace 92 TOYOTA CAMRY REAR DOOR HANDLE RH
Feb 11, 2007 at 6:35 AM
MMPRINCE3000
  • 133 POSTS
Best idea is to get a Haynes manual for the repair. Generally you have to take the inside panel off to get to the outside door handle. Could be a loose bolt but generally they are plastic housings that crack and must be replaced. You can try to repair it with an epoxy glue, but you need to know the type of plactic to get the correct epoxy.
Feb 14, 2007 at 10:39 PM
Suggested Repair
Consult a Haynes manual for the 1992 Camry. Remove the interior door panel to access the outside rear door handle, and check for a loose bolt. Cracked plastic housings generally must be replaced; epoxy is only a possible temporary repair if the plastic type is known.
Conversation Summary
The owner asked how to replace the right rear outside door handle on a 1992 Toyota Camry. The expert recommended a Haynes manual, removing the interior panel for access, checking for a loose bolt, and replacing cracked plastic housings rather than relying on epoxy unless the plastic type is known.
