1998 Toyota Camry Exterior Driver's Side rear door handle r
RHOLMSTEAD
  • 1998 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 230,000 MILES
I need to replace the driver's side rear exterior door handle. To do so I need to remove the inside door panel. How do I remove the inside rear door panel?
Friday, November 27th, 2009 AT 1:09 PM
KHLOW2008
  • 41,814 POSTS
Hi rholmstead,
I do not have any diagrams to show you so will only be able to provide some written instruxtions.
Remove any holding screws, look out for concealed screws and the panel can be pried out as the edges are clipped on.
If this is a manual window, the regulator handle has to be removed first, use a pice of cloth to slot between the handle and door panel, twist the cloth arounf the regulator and you can get the holding clip to come off and remove the handle.
Saturday, November 28th, 2009 AT 7:27 AM
