2000 Toyota Camry Won't Go Into Gear
JOHN HIGGINS
I have a 2000 Toyota Camry with about 118,000 miles on it. This morning I drove it about 5 miles for a small errand and when I started the car for my return trip the car started but would not go into gear (forward, and or reverse), it seamed to slip into neutral. Can you tell me what could be the problem. Thank you for your time.
Oct 24, 2007 at 1:27 AM
  • 75,988 POSTS
Its probably the transmission control module is missing an input signal and not activating a certain shift solenoid/s. to engage the gear as desired.
Oct 26, 2007 at 6:32 AM
Suggested Repair
Have the transmission control module checked for a missing input signal that may prevent the shift solenoids from engaging the selected gear.
Conversation Summary
A 2000 Toyota Camry with about 118,000 miles started normally after a short trip but would not move in drive or reverse and seemed to slip into neutral. The expert suggested the transmission control module may be missing an input signal and therefore not activating the shift solenoids needed to engage the selected gear.
