2000 Toyota Camry Transmission Fluid Leak
KDMHNL2007
I have a 2000 Toyota Camry with 61,000 miles. Just recently noticed transmission fluid leak. Slow leak but constance. I took it to the gas station mechanic down the street and he put an additive that has a good success rate to stop the leak but not a sure fire solution. I regularly service my vehicle every 3000 miles. What could be the problem? The mechanic said that if the additive does not work than the trans might need to be overhauled. Could it be something else?
Oct 21, 2007 at 11:59 AM
  • 31,937 POSTS
Hi there,
These fixes in a can can do more harm than good. What they do is swell the seal so it takes up for a short while then it will start to leak even worse. but the problem is that all the seals may be affected, then you may be up for a big repair job. Quite often on these front wheel drive cars the drive shaft seal will leak this is about a 3/4 Hr job and the seal is not expensive. If the leak it from the bell housing (internal) then the converter seal may be leaking and the box will have to be removed. If the drive shaft seals are leaking (more than likely) this will be very easy to see with the car on a hoist.
Mark (mhpautos)
Oct 21, 2007 at 1:47 PM
LOSTINMARS
  • 222 POSTS
yes any of these "repairs in a can" are a waste of money and sometimes can cause more problems.
yes as stated above the output shaft seals tend to leak on these. another problem with all toyota fwd vehicles is that the bolts on the trans pan come loose over time and cause the pan gasket to leak.
Oct 22, 2007 at 3:27 PM
Suggested Repair
Avoid stop-leak additives, which can swell seals and worsen leaks. Inspect the vehicle on a hoist: leaking drive-shaft or output-shaft seals are common and relatively inexpensive to replace. Also check for loose transmission-pan bolts and a leaking pan gasket. If fluid is coming from the bell housing, the torque-converter seal may be leaking and the transmission will need to be removed.
Conversation Summary
The owner of a 2000 Toyota Camry with 61,000 miles reported a slow, constant transmission-fluid leak. A mechanic added a stop-leak product and said an overhaul might be needed if it failed. Experts advised against seal-swelling additives because they can temporarily reduce leakage and then make it worse. They said front-wheel-drive Toyota axle or output-shaft seals commonly leak and are usually easy to identify on a hoist, while loose pan bolts can also cause a pan-gasket leak. An internal leak from the bell housing may indicate a converter seal and require transmission removal.
