1990 Toyota Camry No Fuel
PETE56
Where is the fuel pump located on a 1990 toyota camry, engine size is 2000?
The car seems to not be getting gas.
It ran as long as you pump the accelerator.
Feb 3, 2007 at 8:03 AM
JEFTFIELDS
  • 74 POSTS
fuel pump should be in the gas tnk,if your car is fuel inj,if not should be on the front of the block of the moter.
Feb 3, 2007 at 9:22 AM
  • 75,988 POSTS
Lets not blame the fuel pump yet, other things needs to be check prior to condemning the pump.
Get these things check out- the TPS and MAF, and if possible do a fuel pressure check with a gauge not the eyeball or thumb method. Once the above checks out we'll go somewhere else.
Feb 3, 2007 at 7:55 PM
Suggested Repair
Do not condemn the fuel pump yet. Check the TPS and MAF, and measure fuel pressure with a gauge before replacing the pump.
Conversation Summary
The owner of a 1990 Toyota Camry 2.0 asks where the fuel pump is located because the car seems not to be getting fuel and only runs while the accelerator is pumped. A reply says the pump is in the tank on fuel-injected models or on the front of the engine block otherwise. The expert advises checking the TPS and MAF and measuring fuel pressure with a gauge before blaming the fuel pump.
