1993 Toyota Camry Gas Smell After Shutdown
ATHCOACH
1993 toyota camry with 4 cylinder engine....runs great at 169,000 miles.....when i shut the car off,i get a smell of gas that lingers for a few minutes...the smell isnt inside the car but rather from either beneath it or from the rear of the engine compartment.....additionally, im not sure if the smell is there during driving the car as well, but it surely is after i stop...no leaks in the gas lines detected or drips on the ground....any ideas?
Jan 23, 2007 at 4:25 AM
  • 75,988 POSTS
[quote:464ea57936="athcoach"]1993 toyota camry with 4 cylinder engine....runs great at 169,000 miles.....when i shut the car off,i get a smell of gas that lingers for a few minutes...the smell isnt inside the car but rather from either beneath it or from the rear of the engine compartment.....additionally, im not sure if the smell is there during driving the car as well, but it surely is after i stop...no leaks in the gas lines detected or drips on the ground....any ideas?[/quote:464ea57936]
Hows the gas mileage? have the exhaust system check from the exhaust manifold all the way to the tail pipe.
Jan 23, 2007 at 6:37 AM
MIKE H R
  • 3,094 POSTS
not sure there is a vapor return line on that , but i would check it out
Jan 25, 2007 at 11:32 AM
  • 75,988 POSTS
Check your charcoal canister for fuel saturation.
Jan 25, 2007 at 9:29 PM
Suggested Repair
Check the charcoal canister for fuel saturation, inspect the vapor return line, and have the exhaust system inspected from the manifold to the tailpipe. Also note fuel mileage.
Conversation Summary
The owner of a 1993 Toyota Camry reports a gasoline smell after shutdown from under the car or the rear of the engine bay, with no visible leaks or drips. Experts suggest checking fuel mileage, the exhaust system, the vapor return line, and the charcoal canister for fuel saturation.
