1994 Toyota Camry Fuel Filter Location
POPSICLECHRISTINE
where is the fuel filter located on a 1994 toyota camry
Aug 27, 2006 at 9:33 AM
MIKEYBDMAN
  • 623 POSTS
The fuel filter is up by the brake booster near the front of the car here is a diagrams to show you where and a guide to walk you through the process.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. Cheers,
Aug 27, 2006 at 9:47 AM
BRENT32
Thank you! I love this site.
Nov 20, 2018 at 2:44 AM
DENNIS FOX
Where is fuel filter located?
Nov 20, 2018 at 2:44 AM (Merged)
  • 75,988 POSTS
The fuel filter is mounted on the driver side of the engine compartment, below the charcoal canister
https://images.2carpros.com/forum/automotive_pictures/12900_fuel_filter_4.jpg
DEEANN919
Engine Performance problem
1993 Toyota Camry 4 cyl Two Wheel Drive Automatic
How do I locate and change a fuel filter on this vehicle
  • 75,988 POSTS
The fuel filter located under the air intake tube that carries the air to the throttle. Remove that black tube, only 3 screws/nuts and then u see the black filter there. Remove the nut that lies on top of the filter, then the one at the bottom. The bottom one is a bit hard to get to. Then remove the clamp that secures the filter to the car, again only 2 nuts/screws. Replace and reverse directions.
MECONTR
1992 Toyota Camry 4 cyl Front Wheel Drive Automatic 152k miles
where is the fuel filter located on a 1992 toyota camry?
  • 75,988 POSTS
Follow the aircleaner duct before it gets to the throtttle body its right below the duct at driver side-
MOUSA
1990 Toyota Camry
  • 75,988 POSTS
Its located on the driver's side fender well
Suggested Repair
On the 1994 Camry, look for the fuel filter in the front of the engine compartment near the brake booster, on the driver's side below the charcoal canister or air-intake duct. Relieve fuel pressure, disconnect the lines, remove the mounting hardware, replace the filter, and reinstall in reverse order.
Conversation Summary
The original poster asked where the fuel filter is on a 1994 Toyota Camry. An expert said it is near the brake booster at the front of the car and linked a replacement guide. Later replies about 1990-1993 Camrys placed it on the driver's side of the engine bay, below the charcoal canister or air-intake duct, or at the driver's-side fender well, with basic removal steps.
