Fuel pump
PETE56
  • TOYOTA CAMRY
Where is the fuel pump located on a 1990 toyota camry, engine size is 2000?
The car seems to not be getting gas.
It ran as long as you pump the accelerator.
Saturday, February 3rd, 2007 AT 4:03 PM
JEFTFIELDS
  • 74 POSTS
Fuel pump should be in the gas tnk, if your car is fuel inj, if not should be on the front of the block of the moter.
Saturday, February 3rd, 2007 AT 5:22 PM
Lets not blame the fuel pump yet, other things needs to be check prior to condemning the pump.
Get these things check out- the TPS and MAF, and if possible do a fuel pressure check with a gauge not the eyeball or thumb method. Once the above checks out we'll go somewhere else.
Sunday, February 4th, 2007 AT 3:55 AM
