1992 Toyota Camry Fuel Pump
LILJ25IN08
  • 1992 TOYOTA CAMRY
Engine Mechanical problem
1992 Toyota Camry 4 cyl Front Wheel Drive Automatic
How do I change out a fuel pump. And where is it located at?
Friday, June 13th, 2008 AT 11:50 AM
KHLOW2008
  • 41,814 POSTS
Hi lilj25in08,
The fue pump is located in the fuel tank.
You need to remove the service hole cover under the rear seat to get access to it.
1. Remove fuel tank cap to release pressure.
2. Disconnect wire socket and fuel hoses.
3. Remove retianing screws.
4. Take out fuel pump housing.
Becareful when reinstalling, ensure float is not restricted.
Saturday, June 14th, 2008 AT 10:51 AM
