1998 Toyota Camry Door Handle Broke Off
TIGERS04
1998 Camry. The external door handle broke off when I tried to open my door. When I called the dealer they said it would cost $250 in parts and labor to replace. Any less costly suggestions?
Oct 1, 2007 at 4:29 AM
FISHERMAN
  • 937 POSTS
[quote:32bcfdec52="tigers04"]1998 Camry. The external door handle broke off when I tried to open my door. When I called the dealer they said it would cost $250 in parts and labor to replace. Any less costly suggestions?[/quote:32bcfdec52]
Hello!
well get it on the Junk yard, and replace it yourself...
its not that hard but be sure to get it the same color,
those handles are having a problem, they break so easy!
Good luck!
Oct 1, 2007 at 5:00 AM
TOPHER_TAB
I have the same problem and so does my friend that has the same car. I know its cheaper to replace it from parts from a junk yard, but how do you go about replacing it? I looked at doing it but don't know where to start.
Dec 21, 2007 at 7:20 AM
Suggested Repair
Source a same-color exterior door handle from a junkyard and replace it yourself instead of paying the dealer parts-and-labor quote.
Conversation Summary
The owner of a 1998 Toyota Camry said the exterior door handle broke off and the dealer quoted about $250 to replace it. An expert recommended buying a matching-color handle from a junkyard and installing it yourself, noting these handles break easily. Another owner asked how to start the replacement, but no procedure was given.
