1999 Toyota Camry Door Locks Off
MKARRA
1999 Toyota Camry, 150000 miles. I recently gave my car to the mechanic because 2 minor issues 1) my driver side door handle (the plastic frame and handle) broke 2) my inside light was not turning on . He replaced the handle only and glued the plastic frame that goes around the handle with glue and said the part only comes with the handle and not the entire plastic frame. He said for the 2nd problem he could not fix it since replacing the bulb did not work – he would have to see if it involved electrical wiring. I told him not to do anything else since he would charge me by the hour to figure out what the electrical issue was. When I got the car back the automatic door lock (I do not have keyless entry) did not work when the car is turned off. It will lock all the doors as long as the car is on but does not do anything when the car is off. This was working fine before I gave it to him. He says he did not do anything and it may be a coincidence. I am not sure what exactly happened and it may or may not be a coincidence but I need to know what may have caused the problem. Any ideas? Thanks.
Aug 13, 2007 at 10:09 AM
  • 75,988 POSTS
[quote:4f2f105a61="mkarra"]1999 Toyota Camry, 150000 miles. I recently gave my car to the mechanic because 2 minor issues 1) my driver side door handle (the plastic frame and handle) broke 2) my inside light was not turning on . He replaced the handle only and glued the plastic frame that goes around the handle with glue and said the part only comes with the handle and not the entire plastic frame. He said for the 2nd problem he could not fix it since replacing the bulb did not work – he would have to see if it involved electrical wiring. I told him not to do anything else since he would charge me by the hour to figure out what the electrical issue was. When I got the car back the automatic door lock (I do not have keyless entry) did not work when the car is turned off. It will lock all the doors as long as the car is on but does not do anything when the car is off. This was working fine before I gave it to him. He says he did not do anything and it may be a coincidence. I am not sure what exactly happened and it may or may not be a coincidence but I need to know what may have caused the problem. Any ideas? Thanks.[/quote:4f2f105a61]
Try checking the door 25amp fuse/gauge10amp./power 30amp-if they okay check the power main relay it powers the intergration relay-from the intergration relay it goes to the door locks.
Aug 13, 2007 at 10:46 AM
Suggested Repair
Check the door 25-amp fuse, gauge 10-amp fuse, and power 30-amp fuse. If those are good, check the power main relay, which powers the integration relay that controls the door locks.
Conversation Summary
The owner of a 1999 Toyota Camry says the power door locks stopped working with the ignition off after a mechanic replaced the driver door handle and checked an interior light. The locks still work when the car is on. The expert recommends checking the door 25-amp, gauge 10-amp, and power 30-amp fuses, then the power main relay and integration relay.
