Child Saftey Lock
EDVIR
I have a 1997 Toyota Camry LE V6 and one of the rear passenger doors will not open from inside the car. I believe that the child safety switch on the door is not being set to allow it to open. Is there a way I can fix the child safety lock switch? I know where the switch is and have moved it to lock to unlock numerous times. I still can not open the door from inside the cars. Is there a simple way to fix this problem without having to take the door apart?
May 26, 2007 at 2:49 PM
  • 55,676 POSTS
You will need to replace the latch assembly they where out which is common on that car. Here is a guide to help you get the door panel off
https://www.2carpros.com/articles/door-panel-removal
The latch you will need to get from the Dealer.
Cheers, Ken
Jun 5, 2017 at 9:32 AM
