i have a toyota camry 1993 running good. But I got one problume with front driver side door. Its not opening I tried from inside and outside. But its not working. Can I get the solution.
thanks
shaz
Friday, June 27th, 2008 AT 1:30 PM
KHLOW2008
MECHANIC
Hi shahzaddgk,
The door latch unit should be faulty or its linkages detached. You need to remove the door inner panel to ge to it.
Sunday, June 29th, 2008 AT 2:18 AM
SHAHZADDGK
MEMBER
Thanks for reply. The thing is that I tried my best to remove the inner panal but I m not able to remove it some screws are placed behind the deshboard and I m not able to open it. Do u have any option.
Thanks again
shaz
Sunday, June 29th, 2008 AT 7:44 PM
KHLOW2008
MECHANIC
Hi shahzaddgk,
Apart from forcing the door panel out, you can try removing the door glass outer moulding and try to use something to get at the door latch.
