Door and truck does not opening with the remote
159,000 MILES • 4 CYL • 2WD • AUTOMATIC
MAXLIFTED
there was a linkage in my fuel tank and all the fuel spilled out. Then after, i discovered that my remote is no longer opening or locking the doors and even the trunk. When the remote is pressed, you hear the normal sound as if the doors/trunk is open but will not open. When I tried locking the door centrally from the driver's and passenger side, it still does not open and lock. I now have to lock all doors manually (by moving the lock forward/backward) could this be a fuse or relay problem please?
Dec 26, 2016 at 9:35 PM
HMAC300
  • 48,601 POSTS
it may be a weak battery in remote. also, if you hear the door locks moving it may need lubing more than anything or a weak battery in car. Have the battery checked for condition including load test. most places do for free. then have it scanned for codes by a mechanic there may be a remote/transponder system problem.
Dec 26, 2016 at 9:55 PM
