camry speedometer
KAILAI
I have a 1993 Toyota Camry LE 4 cylinder with 115,000 miles. The speedometer reads about 20 MPH lower than actual. Check engine light is NOT on & a reading of the ECU shows no codes. Any idea how to repair?
Jul 20, 2007 at 11:33 AM
  • 75,988 POSTS
[quote:80c6181ded="kailai"]I have a 1993 Toyota Camry LE 4 cylinder with 115,000 miles. The speedometer reads about 20 MPH lower than actual. Check engine light is NOT on & a reading of the ECU shows no codes. Any idea how to repair?[/quote:80c6181ded]
Start with the vehicle speed sensor on the tranny before you get to the combination meter/VSS.
Jul 20, 2007 at 11:52 AM
