1987 Toyota Camry 16V Charging
REZAISAHAC
i have a 1987 toyota camry station wagon, 4cyl 2.0 automatic transmission a/c power steering , front wheel drive. my alternator is charging at 16v dc i wanna know if that is good or a bad charging voltage cause the auto parts store is saying it is good and not want to warranty the alternator but my tester is saying it is bad.So in this case what to do
May 24, 2007 at 3:36 AM
  • 75,988 POSTS
[quote:981b89eb64="rezaisahac"]i have a 1987 toyota camry station wagon, 4cyl 2.0 automatic transmission a/c power steering , front wheel drive. my alternator is charging at 16v dc i wanna know if that is good or a bad charging voltage cause the auto parts store is saying it is good and not want to warranty the alternator but my tester is saying it is bad.So in this case what to do[/quote:981b89eb64]
16volts your cutting it real close on overcharging is that a no load or load test. Normal range should be 13.5-15.5, you're just 0.50 volts over
Your problem on the 16volts is the IVR not maintaining the correct voltages.
My opinion is exchange it or take the money and run.
May 24, 2007 at 9:56 AM
Suggested Repair
Exchange the alternator. About 16 volts is slightly above the normal 13.5-15.5 volt charging range and indicates the internal voltage regulator is not holding voltage correctly.
Conversation Summary
The owner of a 1987 Toyota Camry station wagon reports the alternator charging at 16 volts DC. The parts store says the unit is good and will not warranty it, while the owner's tester says it is bad. The expert says 16 volts is slightly high and attributes it to the internal voltage regulator, recommending that the alternator be exchanged.
