2002 Toyota Camry totally dead car
GEEZERDAD
  • 2002 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 10,000 MILES
I stopped at a store on the way home, and while my son went in for a couple of minites I listened to the radio with the engine off. When he came out, I tried to start the car but it didn't make a sound. In fact absolutely no electrical anything worked. I called a tow truck and he tried to jump start it but the car stayed dead. I had the battery tested and replaced it. I installed it and the only thing that worked momentarily was the door ajar indicator on the dash display. After a few seconds of display it went off too. I disconnected the battery so as not to have it drain, and now I'm thinking. Could it be the computer? I really can't afford to replace it now. Can you assist me? Thank-you, Chris
Tuesday, November 2nd, 2010 AT 8:27 AM
Inspect and test all the fusible links.
Tuesday, November 2nd, 2010 AT 8:54 AM
GEEZERDAD
[quote="rasmataz"]Inspect and test all the fusible links.[/
quote]
Its the fusible link from the pos. Battery cable to the bottom of the under hood fuse box. Is that a part that is replaceable by the owner?
Wednesday, November 3rd, 2010 AT 8:28 PM
The fusible link is a wire between the battery positive post and engine room relay box and also check the alternator fuse
Thursday, November 4th, 2010 AT 3:24 AM
