2000 Toyota Camry Door Ajar Light
TACOPRINCESA
I have a 2000 Toyota Camry, with 108,000 miles on it and alarm. Runs perfect!!! But lately when I make a right turn the door ajar lights comes on and my automatic doors unlock. Sometimes it does this when I pass a bump on the road and even sometimes when I just drive straight. Seems haunted to me. I replaced the battery on my alarm, but it continued to do this. What can I check? Loose wiring???
May 25, 2006 at 5:58 AM
LOSONE
  • 1,616 POSTS
It sounds like you have a loose or defective door light switch. The most used door is the drivers door. Check it out Good Luck
May 26, 2006 at 10:31 AM
Suggested Repair
Inspect the driver's door ajar/courtesy light switch for looseness or failure, since a faulty switch can falsely indicate an open door and unlock the doors.
Conversation Summary
The owner of a 2000 Toyota Camry reports that the door ajar light comes on and the automatic doors unlock during right turns, over bumps, and sometimes while driving straight. Replacing the alarm battery did not help. The expert suggests a loose or defective door light switch, most likely on the frequently used driver's door.
