1999 Toyota Camry oil leak
SBROWNIE
  • 1999 TOYOTA CAMRY
  • 4 CYL
  • 72,000 MILES
Dealer told me oil leak from pan. Need to repair lower oil pan gasket. How?
Tuesday, January 27th, 2009 AT 10:13 PM
  • 31,937 POSTS
Hi there,
There is no gasket on the sump, it is sealed with a chemical bonding agent, you must use the correct Toyota sealant for this job, The sump will be difficult to remove and you must not try and pry it free with screw drivers as you will bend the flange, there is a special wide chisel that is used to separate the sump from the block, with the exhaust and lower guards removed drain the oil and unbolt the pan, you will have to clean every last remaining trace of old sealant or the bond may not take completely, follow the instructions on the tube exactly or you will still have leaks to deal with.
Mark (mhpautos)
Tuesday, January 27th, 2009 AT 11:00 PM
