Recently I had the car in the shop and had everything fixed that needed fixed. All oil leaks fixed, gaskets changed any thing that needed done was done. Yesterday the car started leaking oil again. When it is driven you can smell the oil burning. I can see that it is leaking from the center of the engine. It is dripping on the flex pipe that hangs just underneath it. Can you tell me where it might be coming from and how to fix it? Thank you.
May 28, 2013 at 12:45 AM
