My check engine light is on. The car has no symptoms. The egr valve and the oxygen sensor has been replaced because of obd codes, but car is still reading code 0401-egr flow insufficient. I don't know what else to do. I need the car to pass inspection. Egr port was also checked and cleaned and hoses were checked for leaks.
SPONSORED LINKS
Sunday, October 24th, 2010 AT 6:20 PM
