1999 Toyota Camry check engine light
MAGGIE500
  • 1999 TOYOTA CAMRY
1999 Toyota Camry 4 cyl Front Wheel Drive Automatic
I have a check engine light that worn't go off. Two great repair shpos, including a gold shield smog test and repair shop, have fixed everything they can find, including following a service bulletin for the evap system. Light still comes on after about 50 miles. HELP, Please~!
Thursday, June 5th, 2008 AT 12:31 PM
KHLOW2008
  • 41,814 POSTS
Hi maggie500,
What is the error code of the check light and what has been done so far?
Thursday, June 5th, 2008 AT 12:47 PM
MAGGIE500
Thanks for replying. I'm at work and didn't bring the paperwork with me. Sorry ! DUMB.
However, the smog repair shop ran a full diagnostic with the smoke machine and found the service bulletin and installed a part which was to have fixed it. Also the evap hose was replaced. They say it's a common problem with the 1999 camrys. They don't know what else to do.
Thursday, June 5th, 2008 AT 12:57 PM
KHLOW2008
  • 41,814 POSTS
Hi maggie500,
No problem, get the data and let me know so we can try to sort it out.
Thursday, June 5th, 2008 AT 1:02 PM
MAGGIE500
Thanks so much for your help! I will try again when I have the proper paperwork to assist you.
You have been wonderful !
Thursday, June 5th, 2008 AT 1:18 PM
