My check engine light is on so I had a smog check guy check it and these codes came up po125 & p1130, po125 says insufficent coolent temp for closed loop, fuel control. P1130 says lack of ho2s-11 fuel trim @ limit how can I fix this or do I have to take it to a mechanic, I changed the egr valve, and mudule, catalic converter thank you, ernie
SPONSORED LINKS
Thursday, December 17th, 2009 AT 4:27 AM
