1999 Toyota Camry
ANDREW FARRELL
  • 1999 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • MANUAL
  • 10,900 MILES
HOW DO I CHANGE MY VALVE COVER GASKET?IF THERES OIL IN 1 OF MY PLUGS IS IT BECAUSE OF TGHE SEAL?
Sunday, October 24th, 2010 AT 1:32 PM
KHLOW2008
  • 41,814 POSTS
Hi ANDREW FARRELL.
A bad valve cover gasket would not result in oil getting to the spark plug tubes.
The sprak plug tubes are isolated from the valve cover and the only way oil can get in is via the tube itself, at lower end of cylinder head, which is very rare.
From top, the plug tube extends out of the valve cover so oil cannot get in, unless the sealing bush is leaking and flooding the exterior of the tube.
When the spark plug wires are removed, you would see a large hex nut around the plug tunes. Removing the the hex nut would allow you to remove the valve cover. Of course other components that are above or connected to the valve cover should be removed as well.
Monday, October 25th, 2010 AT 8:29 AM
