2002 Toyota Camry Valve Cover Gasket
2002 TOYOTA CAMRY
LUCAS2842
Engine Mechanical problem
2002 Toyota Camry Front Wheel Drive Automatic 136200 miles
I was told my valve cover gasket and power steering line is also leaking. Wouldn't I know if something is leaking? I have not noticed any spots on the garage floor. The estimate for these repairs is over $700. If the repairs are needed, is this estimate reasonable?
Feb 10, 2010 at 6:11 AM
BLUELIGHTNIN6
  • 16,542 POSTS
may not always have wet spots under vehicle from a leak. best way to know is to simply visually inspect the component and also check the fluid levels of each suspected component... Estimate below is based on 4 cylinder engine, 6 cylinder estimate will be slightly higher..
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_1627.jpg
Feb 10, 2010 at 7:26 AM
