1998 Toyota Camry very noisey under valve cover
1998 TOYOTA CAMRY
59,000 MILES • 4 CYL • 2WD • AUTOMATIC
COUNTYWIFI
I had a mechanic check the valve train and he said both cams and related parts needed to be replaced. He pulled the valve cover and checked this. He said they were both overly worn for the mileage. My question is can I just do this myself?
Feb 28, 2009 at 9:10 AM
GRSMNKY
  • 33 POSTS
unless you have done this before or have PROPER tools and toyota specs and step by step toyota manual (not chilton or haynes), I would leave this kind of job to the toyota dealership mechanic. I am also skeptical of the premature cam wear diagnosis.
Mar 1, 2009 at 4:10 AM
COUNTYWIFI
Thanks for the reply and I will take your advice on this one. I definitely don't have all the proper tools or the specs............
Mar 3, 2009 at 8:23 PM
