1997 Toyota Camry door broken
170,000 MILES • 4 CYL • FWD • AUTOMATIC
PRINCEMOOSE
Hi im a student and i drive a 97 camry. someone tried to break my locks and steal my car but was unseuccessful. but now the passenger side lock does not work from the outside and the door handle does not work on the inside and the outside. what could be the problem and how do i open the door now?
Dec 6, 2007 at 3:39 PM
  • 31,937 POSTS
Hi there,
Check for fluid loss. check each wheel and the flexible brake hoses. if you have lost all fluid you should be able to see wher it is leaking. Do not drive even if you get a pedal when adding fluid as you may run out of brakes while driving. Report any leaks and then i can advise you on what to do.
Mark (mhpautos) :D
Dec 6, 2007 at 5:27 PM
