1997 Toyota Camry
BIMKA
  • 1997 TOYOTA CAMRY
1997 Toyota Camry 4 cyl Two Wheel Drive Automatic
How to fix fuel filler door opener?
Thursday, September 16th, 2010 AT 7:54 PM
DSPLC
  • 220 POSTS
The spring inside your fuel door broke. Common problem for old Toyotas. To release your fuel door, lift the gas lever inside and cushion under the handle with something to keep the lever up and then go the fuel door and insert a credit card on the crack of the fuel door and open it manually.
You need to replace this one (gas filler door spring). The V metal part snap out of the plastic. Easy to replace.
https://www.2carpros.com/forum/automotive_pictures/89255_fuel_door_2_1.jpg
https://www.2carpros.com/forum/automotive_pictures/89255_fuel_door_1_1.jpg
Thursday, September 16th, 2010 AT 10:54 PM
